3000 exhaust options
gears
Anyone got any pics or parts to convert a 3400 (gas) from a vertical exhaust to horizontal?
I could run a big J bend from the hood down but figure there's another option as I see a horizontal exhaust manifold option on the YT parts page....
Thanks showcrop - that pic might explain why my valve went bad and I had no compression -
The tractor had a pipe sticking in the vertical exhaust that did not have the collar around it, 8+ yrs out in the weather likely allowed enough water down there that the crud/crust/debris in the exh manifold gunked up #3 cyl enough to have no compression and would explain the amount of water in the crankcase.
you can wedge an N pipe under there ;)
That looks like it'd be a bit cheaper than the $197 for the 3000 specific pipe going to the $57 muffler.....
So with that setup I'd just get the heat shield for the oil canister and be set to go.
Great pic, thanks SouNd
