I have an 861 (gas), I currently run a 6' rotary cutter. I have about 20 acres of pasture that I need to cut 2-3 times a year.
The first time is to knock the tops of the fescue off to reduce chances of pink eye. The next couple of times is to cut the weeds which I have a lot of. For most of this, I cut very high, the tractor does not bog much, but it takes forever. It's killing me trying to keep up with this in the summer, I have many other things that need to be worked on if you know what I mean.
So, now I am converting roughly 20 more acres to pasture this year. Mowing is going to kill me, takes a long time and I have a lot of trees interspersed in most of it.
[b:250a74d91e]
Can my 861 pull a 7'?[/b:250a74d91e] My other option is to run 2 tractors at once. My oldest boy is now old enough to mow with a tractor, but I don't trust him with a rotary cutter around trees just yet, but a finish mower would be fine. Has anyone tried cutting pasture really high with a finish mower?
Lastly, I am going to pick up a PTO boom sprayer this year and try and cut back on the weeds (2,4-d I assume), but am not sure this will eliminate my weed mowing? Any comments appreciated, thanks!
[b:250a74d91e]
