RICK IN GA
Hey everyone Since I finished the 8N it was time to give a little tlc to the 1841. I had to take apart the power steering reservoir to clean up and seal for leaks. I replaced the low pressure hose. It seems like it could use a cylinder rebuild. It is the cable driven system and is missing the seals on top of the actuator. Seems a bit sloppy but works.
I need a couple things for this tractor.
1) The throttle linkage is missing the foot pedal and seems to have been modified. WOuld love to see a photo of someone's linkage that is as it was from factory.
2) Would love the half round steering wheel that should have come with the tractor.
3) would love the original seat. If someone had a frame I would get it reupholstered.
4) Need the oil bath air filter system and fuel filter housing and bracket.
5) Need the typical SOS starter switch which is just like the glow plug switch.
This would be a great start to an already running tractor. Thanks for your help in advance. Rick
