1970 Ford 4000 3cyl Diesel tractor built in Basildon, UK
viziers
So I am doing a little bit of a resto on some parts and wanted to know if I take the 2 bolts that hold on the control lever stop assembly if it just slides out or something else?
This pic is not of my tractor but the lever is the same as what is on mine. This is Jerry D in NC's pic
vizi
Can anyone explain to me how to remove the hydraulic lift handle assembly?? I removed the 2 bolts that hold it to the lift cover but noticed it feels like it is being held in by something else like the draft control lever.. I would like to remove it so I may blast it and then paint it but don't want to mess anything up inside the lift cover or knock it out of alignment if that is possible?
vizi
