'66 Diesel
Symptoms:
1. Very slow warmup. Can take 20-30 minutes of running for hyd fluid to start flowing out of the pump.
2. Lots of air in the system. I installed a valve on the pump and open it to bleed out the air. Once the fluid starts to flow, air can shoot out or it may just bubble out. This happens when I shut engine down for > 30 minutes
3. Once fluid is flowing and air bled, lift works just fine. Lifts at least 800 lbs at a decent rate.
Ideas? Thanks in advance.
Symptoms:
