Replacing 9700 rear window
How do you get the hinge to separate at the top. I figured you would flip the frame up and push in and pull out but i cant get it apart. And i would just take those screws out instead if some werent seized in there. I have a new back window to go in.
end of hinge slots are bent, so I would take a punch or nail or correct size tool and open them up... if the old window is broken, then you could use a hammer to help it out... But on the last one I replaced, they just slid out. So maybe I was lucky. abundant doses of wd40 and exercising the hinge would help.
I ended up geting it. The ends on mine have tabs so they dont slide out. But i pulled the upper weather stripping down and lifted up high and it poped out.
