Tire question
alg
Guys,
Will 7.50 x 16 tires and rims fit on a 63'
ford 4000 with the adjustable front axle.? I'm
concerned about the clearance on the top of the
spindle. Right now it has 6.50 x 16 mounted on it.
I am assuming you have a row crop... I have 6.50's on a 671 with ok clearance. The 961 has 6.00 on it with ok clearance but I think it would be pretty tight with 7.50's. You want near an inch of clearance. Best way if a neighbor has 7.50's to try one just for clearance. Front hubs are pretty universal with 6 bolt pattern. Could always turn the dish out which could increase steering effort but give plenty of clearance.
Doubtful without reversing the rims.
I have 6.60X16 front tires on my 64 4000 and there is little clearance between the tires and the spindles.
Dean
I run tires that size on my 841 all the time but not sure if they will work on your machine
