Couple of questions.
1 will a 304 Genisis engine bolt to a 4000 bell housing and 2
will an 8 speed 4000 transmission bolt to a 4000 SOS rear.
Not worried about PTO or hydraulics.
Yes, they share the same bolt pattern. I wouldn't expect a very long life from the transmission behind that engine, though.
I'm not sure, but I think a 4000's 8-speed will bolt up to a 4000's SOS rear end. The gear ratio will be wrong, though.
Select-O-Speed differential gears had 6.67:1 ratio, and all others had 3.50:1, so a S-O-S rear would reduce it more, down to almost half as fast. Sort of like those new Verizon commercials - you would have a half-fast tractor.(say it fast) :wink:
