Tom Bond
Got my first snow moving of the season in last weekend using the NF as opposed to last years WF mount. You guys were right. The NF is much more nimble. Slides a little when wheels are turned all the way but punch either brake and that thing turns like a top! I think I had as much fun spinning that thing around as I did actually moving snow! I'll just keep the NF on and probably hang on to the WF. I'm sure it will just get tucked away in a corner somewhere and never used again.
The original Zero Turn! I love all of mine.
Just be careful if you're hauling something not 3pt hitch or it can
get hooked on a tire and hauled up over the seat with you on it!
well.......that's easy..keep your eyes open and find a beater tractor to set on that spare front end...LOL...project!
couple more NF tips
in heavy mud or wet snow, sometimes it will build up between the fronts.
Usually it is as simple as backing up a few feet and it will fall out.
Very heavy clay mud and having to do a lot of work,
sometimes a front wheel adjustment on some brands, or just flipping the wheels on others will give more space between.
Only takes a minute, and easy to put back when the mud dries.
(I think they look silly with the fronts wider, but sometimes ya do what ya gotta.........then switch em back to 'pretty' before anybody sees) :D
