Mike St. Martin
This week I purchased a used backhoe attachment
for $2000 to use on my tractor.
The tractor is a 1963 Ford 4000 with 19-105
loader and front mounted pump (11.5 gpm @ 1800
psi). The Parker loader valve has two unused
ports on top labeled "R" and "CO" (or possibly
"G" and "D").
The backhoe attachment is a Bobcat 6TB with
frame and two 1/2" quick couplings (red and
green tie wraps). I will visit a Bobcat dealer
next week to get a manual and determine the
type of valves used on the backhoe (open or
closed centered).
I could use some advice on the best way to
connect the backhoe hydraulics.
1. Is it possible the loader valve has power
beyond capability and I can connect to these
ports? "R" = Return, "CO" = ?
2. Should I connect prior to the loader valve
with a type of priority valve?
3. Are there other possibilities I should
consider?
I appreciate your comments and advice.
"G" and "D").
closed centered).
consider?
