lot to what you say. Most nay-sayers comment on stability/tip over...........do they ever stop to think that those front axles have a chassis pivot point in the center? That pivot negates any left/right stability, at least until the limits are hit & that is probably too late. Wide front looks more stable, but that is most of it, I'm afraid. At best, it appears to raise the pivot point about 18 to 24 inches higher than a narrow front. Is that good or bad? I think it is easier to steer a narrow front, but also easier to sink in wet ground. I have & use both, so I'm covered. Apply them in right places for the right job & all is well.(quoted from post at 06:07:54 01/06/15) Put me down for narrow front. better maneuverability, easier to store and transport if more than one tractor are on the trailer. If you want a wide front buy a utility model.
Kirk
(quoted from post at 07:30:39 01/06/15) I will add this to my post above.
If you ever have to split a RC you will definately wish you had bought a utility.
Those extra frames make them a PIA.
If you don't have steep hills you won't care much about the stability debate,(quoted from post at 23:43:03 01/05/15) Guys, thanks for all your input. It gives me a few things to consider. My main use, at least initially would be light work around the place as I restore/refurb for use during events I participate in with the antique tractor/machinery club I belong to. I initially favored the wide front end for the look I liked, but in browsing the internet forums and images, am now not so sure and posted to get some experienced opinions.
