good Morning!!
I have a 1953 jubilee that ran a week ago and now has no power to key. this is what I've done so far
1) replaced 6 volt battery
2) replaced coil, wires, points, condenser, spark plugs al437 gapped both points and spark plug .025 note wires in 1243 firing order.
3) replaced new safety foot starter, and key switch
4) replaced starter relay (solenoid)
5) voltage regulator
6) terminal block
7) replaced positive battery cable, negative battery cable, and new starter cable.
sorry for the lengthly post
I can get it to turn over jumping the solenoid but won't start.
Someone told me to set the flywheel to 8 degrees btdc on the compresstion stroke.
Please help if you have any idea what I'm missing Thank you!
6) terminal block
