The Hydraulics are slow when lifting a weight on the 3 point linkage and on the front bucket. Reving the engine does not speed up the rate of lift, as it use to do.
I have replaced the hyd oil, new filter on the gear driven pump (left side engine), new hyd pump and I am still having the same problem.
I suspect that it might be the flow control valve that could be the problem. Or perhaps the setting of it has been moved and needs to be corrected.
Can someone advise just where I should look next. I currently have the hyd life cover off the tractor. Should I remove the flow control valve and rebuild it, or should I put it back together and test it first? Do these tractors have alot of issues with the flow control valve.
tks Darrin
tks Darrin
