Need help identifying an old ford backhoe
justin2839
New User
I have recently purchased an old ford backhoe and was trying to locate the service manuals for it but I am having trouble identifying what model it is.
The stamped model number is 440210, SN C134201 6 D C which leads me to believe it is a 4400, it is a 3cyl gas and has no pto so all that agrees but “0” is not a transmission identifier that decodes to a 4400. Also it seems to be a 4 forward and 4 reverse gear transmission, put it is not shuttle shift. First seems to be to the right and forward with 2nd to the left and forward. First reverse is right and aft with reverse second to the left and back. Than to the right it has a second lever High/low. The shift pattern is an H pattern and seems like it is as it should be but I can’t find any information that indicates that this transmission exists. Any help would be appreciated, thanks Justin
I did wonder about it possibly being a “G” but the service manual I bought didn’t list that as an option. Of course it didn’t list that shift pattern transmission either. So does that mean that this is a 4400 and the manual I purchased just omitted the transmission I have, or do I have the incorrect manual?
It is a 4400 and I haven't seen that transmission listed in any of the service manuals and the only tractor I've seen with it is a 3400 that my brother has.
440 = 4400
2 - gas/vertical exhaust
1 - no PTO
G - 4x4 manual transmission
Mark
The manual reversing transmission started out as a 4x4, and was switched to a 6x4 within the first couple of years of production of the 3 cylinder models. The transmission code for the 4x4 was G.
The parts site shows that the switchover was on April 1, 1968, at the same time that they switched the sheet metal and grill styling and changed the series designator from a number to a letter.
C5NN7N106A GEAR Assy., 2nd & 4th Speed, 32T, Years: 01-JAN-65-31-MAR-68
E6NN7N413AA GEAR SET Gear Assy., 2nd & 5th Speed, 35T, Start Year: 01-APR-68
