I am trying to figure out how to remove the fuel injectors on my new to me Ford 545A. We had it running a few weeks back then went to start it and the engine with not turn over. Starter turns the engine 1/4" or so and when I took off the starter I could only turn the flywheel about 1/2 way until resistance. I can turn it back the other way but I hit resistance also. I thought hydrolock so I was going to try again to turn the flywheel with the injectors out but not sure how to remove. Removed the two nuts on the left and right of the injector. Then what pull straight out (tried to force a little with a screwdriver but would not move). Do you have to force these injectors out. Can I remove try to turn over and reinstal the same injectors and seals or do i need new ones. Starter was rebuilt about a month ago. Any help would be appreciated. I do not have the money or equipment to bring it to a mechanic so I have been learning fast about diesels and hydraulics.
