rear hub NAA
The only possibility would be the 8N... I can't say for sure on
that. None of the newer models are the same.
The 8N uses the same hub and axle as the Jubilee/NAA, and that would be the only model. If you are looking for a used axle, be aware that the early 8N's did not use an inner seal like the Jubilee/NAA, so will not have the surface machined for the seal to ride on. The 8N got the seal during the 1950 model year. All new replacement axles have the machined surface to fit tractors with and without the inner seal.
NAA and 8N's were the only tractors to use that setup. Normally when the axle is determined to need replacing, the hub also warrants replacement. When all new, the brakes and seal positions are returned to a good surface for proper use and future adjustment as necessary. We have a couple new axles here left over from a job where the customer chose to sell his tractor as is and we have extra axles, Dale 920 295 3278
