Ford engine identification!?
joel88
New User
Hello!
I have a swedish manufactured tractor with a ford engine, maybe someone here could help me find where it comes from!
Serial number is *E312623*
Production codes
G
61C09
8E30B
Guess its produced may 30th 1968
But from which model?
I checked the injector nozzles, and found the BDLL150S6665 that is for a 5600.
I can't help with the codes, but if you give us some more
information, I can at least narrow it down.
3, 4, or 6 cylinder? Intake and exhaust manifolds on the same or
opposite sides of the head?
Is there a foil sticker on the valve cover with this info on it?
It could be a school engine though that would be the earliest one I've heard of.
School tractors didn't have any sheet metal on them so they put that sticker on the valve cover.
No foil sticker on this one!
its a 4 cylinder, with manifolds on opposite sides.
They says this machine should be build on Ford 5000, TTT converter and Ford rear axle (industrial?)
Ford sold powertrains to various companies, so I'm
thinking that's what this is. Your date code could
also be May 30, 1978. That would correspond to the
5600 p/n you found on the injector. The round
intake manifold and oil fill location also point to a '76 or newer
model. However... I think it may have been
repowered, as the power steering system is the
older 60's/early '70's style, and the exhaust
manifold is also the older style, exiting nearer
the rear.
Assuming it IS a 5600 engine, it would be a 233
c.i.
Allright!
The tractor (Gigantic F30) is produced in -67
The oilpan is yellow as the tractor en the engine is blue, soo the engine must have been replaced in later years probably!
Either a 5600 or 6600 is what the experts thinks?
Next step to identify should be removing the cylinder head?!
Have a valve set for it (hoping its right now) the plan is to overhaul the head!
What about the injection pump, is this type for any special model only?
(quoted from post at 14:37:25 12/12/14) Allright!
The pump is the Sims Minemec used on MANY four and six cylinder Fords
