With the inline pump with the lift pump on the side the engine must be stopped in the right spot. If there is low resistance on the pump lever bump the starter until there is resistance.
This filter has a water seperator and a filter. Two bleeders on the top. any trick to bleeding which one first?
(quoted from post at 23:44:47 12/12/14) This filter has a water seperator and a filter. Two bleeders on the top. any trick to bleeding which one first?
I think the rear filter gets fuel 1st but it really makes no difference with both bleeders open just close the 1st bleeder when air free fuel comes out and keep pumping until air free fuel comes out of 2nd bleeder then close it.
