richard d hayes
My 841D has hydraulics problems. Today I got the gasket kits ordered and am ready to remove the pump and/or cover. I have looked in each access hole but find no leaking, no air in pump, clean fluid and correct amount. My problems are: (1) the arms will raise the full height but will not lift more than approximately 75 pounds. (2) when arms are raised they pulsate, that is, they will rise to the set elevation and then fall 3-4 inches, then rise again to the set setting. This cycle is repeated about every 10-15 seconds. (3) even though the hydraulics will not lift any weight, I was able to move an RV by first raising the front of the RV to about 30 inches. Then back the tractor under the RV hitch and raise the lift. Once raised, I lowered the front of the RV down on the ball attached to the tractor. The tractor hydraulics did not fall, it held steady where it had been set. The weight on the tractor hydraulics was approx. 800 pounds. Anyone have any ideas where I might start repairing my hydraulic problems. any assistance would be appreciated.
