ford steering motor
JD4320
New User
Steering motor was leaking on tw 35 replaced seals and o'rings reinstalled motor. the steering was backwards thought I had put oil lines on wrong but I had marked them before removal. Reversed lines any way steers good in one direction but not in the other. Thinking there was air in line so I cracked line at steering cylinder with no improvement. Wondering if I misalined something in motor when reassembled it. Any one with some advise would be greatly appreciated
when you took it apart to replace the seals did you pull the drive link out of the rotor pump in the bottom? Sounds like you got it out of time.
Here is the procedure.
(quoted from post at 17:30:22 12/08/14) when you took it apart to replace the seals did you pull the drive link out of the rotor pump in the bottom? Sounds like you got it out of time.
ould be a possibility that I did. Had a little bit of trouble removing top cover off input shaft. Need to take it off and see.
