Hi, Just recently purchased a 1981 Ford 7600 FWD, previous owner had removed the front planetary gears probably due to being broken. I'm hoping to get the 4WD working again so I'm looking for the planetary gears and sun gears (hard to find). Would like to know what other tractors used the same final drives, its a ZF axle with off-set housing.
I want to also confirm what the correct tire size is for this tractor with 4WD as I'm not sure if they changed tire sizes after they dismantled the gears, current back 16.9x38, front 14.9x24. Don't want to get gears and find out ratio of tires is wrong
