I'm hoping Soundguy or other knowledgeable person regarding Ford tractor 6 volt positive systems can help me troubleshoot a problem I have with not getting the generator system charging sometimes on my 1958 Ford 641.
Sometimes the system will charge the battery and I can confirm that with voltage measured at the battery of 7.1-7.4 volts with the engine running. It will charge just fine for the entire time the tractor is running. I can go back the next day, start the engine, and measure voltage again at the battery and only get static battery voltage of 6.4 volts while the engine is running. So, the system is not charging again.
I have followed Soundguy's advice about polarizing a b-circuit generator by momentarily jumping bat to field at the VR terminals. I start the tractor and the static battery voltage does not change. I then use Soundguy's diagnostic check with alligator clip wires at the VR and with the tractor running jumper arm and bat (sometimes I get voltage to come up at this point but not always). I leave the first jumper in place and then I jumper bat to field and the voltage comes up at the battery. After this I remove the two wires with alligator clips and the voltage stays up at the battery and the system is charging. The system will sometimes maintain its charging ability over numerous engine start and stops over several days. However eventually, I'll start the engine and will only get static battery voltage. I have gone back through the diagnostic tests and at the end of the tests with the two alligator clip wires removed, the system is charging again.
Does this indicate I have a bad VR or other source of the inconsistent charging? Thanks for your help,
