(quoted from post at 21:29:20 11/26/14) It's the same narrow front as the old ford 900/901/4000 row crop tractors, except for an adapter plate that is bolted on top.
If you find a narrow front from a 900/901/4000, I'll sell you the adapter plate and bolts.
(quoted from post at 15:58:38 11/27/14)
Thank you for all of the help guys I will try to find one for a smaller tractor and go that route! Does the 7000 have its own narrow front? Thanks again!
(quoted from post at 10:58:38 11/27/14)
(quoted from post at 12:08:46 11/30/14)
I have one from Farmall H under mine. It is nearly a direct bolt-up. There a re a bunch of videos on U tube. Ford 9000 tractor pull Bob Bohondoney.
(quoted from post at 15:24:58 11/30/14)(quoted from post at 12:08:46 11/30/14)
Showcrop, can you explain what you had to modify to adapt the IH pedestal to your 9000?
Thanks, Chad
(quoted from post at 11:58:36 12/04/14)
Machine shop says he doesn't have the plans anymore. He did say he cut it all out of one piece, no welding.
Do you want me to measure it for you?
