Need help. My 68 Ford 4000, 3 cylinder diesel started knocking from a connecting rod. Loud knock! Imbalance. Loss of Power. Still firing on all three. The engine still starts right up and has always run good, been serviced well. I need it to move hay. This is my loader tractor and I don't have a lot of time to waste fiddling with fixing the engine internally. Plus here in VA, cannot even find a shop that will rebuild it, and I don't have time. I am putting in a long-block. This tractor is a keeper.
The PROBLEM is THEY want two serial numbers, the one off the intake manifold and the one off the injector pump. Intake was easy to find, as would have been the block (didn't want that one), but I cannot find the injector pump #. It is a rotary. CAV/Lucas? I know, I have replaced he pump throttle seals, and ordered the o-rings by year model and they fit.
Is the serial number not in sight? I cannot find one.
So where is the serial number? How do you find it?
Wayne
Wayne
