marvel schebler carburetor pdf
cpk
Does anyone know of a pdf file on marvel schebler carbs for ford tractors that can be down loaded to my computer?I have found one file, but it only covers up thru the hundred series.I am looking for one for the 01 series.
The diagram here (sent to another forum member by GlenIdaho some time back) is for the M/S carbs used on x01 series tractors approx '58 to '60 and is for the TSX-769 and TSX-813. I believe there were some differences as the 813 had a larger fuel line and there may be some other changes, I'm not sure. If you need a .pdf file, let me know and I can open my email and send it to you. -Will
Thanks Will but I was searching for a file that tells all info such what carbs fit what series tractor from tsx 769 on up. Also the file I have on the hundred series gives total break down of each carb. It comes in handy from time to time.Thanks again for your reply!
(quoted from post at 18:06:12 11/26/14) Thanks Will but I was searching for a file that tells all info such what carbs fit what series tractor from tsx 769 on up. Also the file I have on the hundred series gives total break down of each carb. It comes in handy from time to time.Thanks again for your reply!
I can tell you that the early 801/901 series had a TSX-662 which was relaced by the TSX-769 and was then followed by the TSX-813. The 662 and 769 used 1/4" fuel line and the 813 used 5/16" fuel line. The 813 also had different mounting stud spacing than the 662/769 so it also had a different manifold. The 662, 769 and 813 all use the same overhaul kit.
The only 601/701 carb I'm familiar with was the TSX-765 but there may have been others.
http://www.readbag.com/oldcarmanualproject-manuals-carbs-marvel-schebler-ms-tr-ford
here's the link
