Last winter I overhauled the steering sector because the tractor would not steer. I had to replace some parts and after I reassembled it the tractor still does not steer correctly. The steering works easy with the wheels off the ground but sitting stationary with the wheels on the ground it cannot be turned and is extremely hard to steer when moving (this is actually an improvement over what it was like before overhauling the sector). Today I connected a pressure gauge to the steering pump and got over 600 psi (should be 650 but the gauge was fluctuating) so now I am thinking about checking pressure at the steering sector but I do not know how much pressure should be at each port. I know fluid is passing through the sector and returning to the reservoir. Any additional advice or ideas are welcome.
Thanks,
Jeff
Thanks,
Jeff
