two spool valve
Harmlar
631 ford has one spool valve under the seat, would like
to mount two spool hyd valve is it possiable to remove
the one spool valve and mount the two spool under the
seat, if not where would be a good place to mount the
two spool other then fender
Ford style single and dual valves are common and available, repops even.
Can get a 2 spool, or buy a generic 2 spool and feed it off the existing single.
New they are about $800.
Watch Ebay or put a free ad in the classifieds here on YT for a used one.
Used doubles go for about $400. But if your single is good you can sell it for $200.
Used Ford dual spool remote valves show up in the classifieds or on ebay from time to time but not regularly. They are becoming increasingly difficult to find.
New valves are available. TISCO still markets single and dual spool valves to fit your tractor. The dual spool valve kit (everything needed to install , not just the valve) is now over $1,000.
Dean
