hard starting naa
what is the difference in a 6volt electronic ingnition to a 12 volt i want to change over to 12 volt and can i use the 6 volt i put an 8 volt battery in it starts right up runs for awhile than dies jump it starts right up the genarater is chargeing i cant figuer out the problem it hasa new wire harrnes battery cables
lets try to answer what i think are 3 different questions.
1, 6v ei and 12v ei? the 6v will be for positive ground, and the 12v neg ground. Not a good soloution to try to run 6v on 12v, via a resistor, even if you swap grounds... getthe ei that matches your battery setup
2, 8v is a bad bandaid fix for anything. if you don't want to fix the 6, go 12. Not a good idea to try to run a 6v ei on an 8v battery, as you'd need to set the charge system to 9+v to charge the battery.
3, how do you know the gen is charging? if it dies, then maybee it is not charging... prove it.
i checked the chargeing it ccharges 7.13 if i put the battery charger on it at 6 volt boost it starts rite up every thing is new i am lost
