Ford TW20 Hydraulic Line leak
Mejiar
New User
My dad and I bought a Ford TW 20 several months back. I was pulling a small root plow when I noticed a hydraulic leak near the battery. The leak is coming from a splice to a hydraulic line. Anyone out there familiar with this tractor. The tractor is back at the ranch and my time to look at and repair is limited to weekends. I'm trying to research before I get back to attempt to fix. This line goes behind two other lines directly behind the battery and appears to end in the general location behind the battery. I couldn't tell where it starts when I last looked at because it was getting dark and it was drizzling. Any help is appreciated.
Guessing a bit here but.
behind the battery is a hydraulic pump mounted in the side of the rear end section. there are small lines that can go to the dual power (if equipped) and the hydraulic cooler upfront on the radiator. That model also had hydraulic brake lines that ran to the rear end. Other may chime in..
sotxbill is correct. If you have the ability, it is best to snap a few photos of the problem for visual aides. Briefly, if the oil is pumping out fast or spraying, I would eliminate the possibility of it being the brakes.
