I finally got my 941 back together (almost) and running. I drove it around a bit to get it warm then went to the field for a bit of plowing to get it up to operating temps. Everything worked as expected. On the way back to the house I noticed the lift was dropping just a little then recovering. I was thinking I needed to bleed the hyd system but I was planning on replacing the fluid anyway. This morning I started it up and the lift picked up and held as it should. I cycled the lift down and back up but it wouldn’t come back up (engine at 1400 rpm). I brought the engine back to idle and the lift slowly came back up. I drained the fluid and found it to be contaminated with water and as it drained out it appeared there was large globs coming out of the sump. I washed about a qt of mineral spirits thru to try and clean out any debris left in the bottom. Anything else I need to do before refilling the fluid?
Thanks,
Scott
Thanks,
Scott
