The crankshaft pulley (#6312 in the parts catalog)
appears to be a single cast wheel, however, on
mine the wheel was attached by (4) 5/8 bolts and
went over the main crankshaft bolt/screw so simply
remove the bolts and off comes the wheel. No need
to remove main bolt and "pull" off.
I need to replace the wheel, but couldn"t find a
similar adaptor type that fits over the nut. The
ones I found are designed to be put under the main
bolt something I would prefer to avoid.
Any help is appreciated. Thanks.
Glen
Glen
