Ford 2000 diesel 3 cyl ground cable location
Recently bough Ford 2000 diesel 3 cyl
the battery ground cable is attached near the battery tray hinge with a bolt.
Does somebody knows where the ground cable was originaly attached. The ground strap between the starter and engine block is missing.
Thanks in advance
Joe Ferguson
Depending witch starter,4 1/2 bolted to front of starter. 5 inch either top starter mounting bolt or front of starter.
