I have oil seeping from the brake shaft that goes through the transmission. I have the Ford service manual and it references using a 954-C puller to remove the bushing and a Tool #818 to replace the bushing.
Before I take this apart or order parts, will the bushing replacement be necessary or will a simple seal replacement likely do the trick?
And are these special Ford tools or will a common bearing puller work?
Any special tricks?
Any special tricks?
