ford 1600 dsl ignition switch.
axe55
The ignition switch (5 post.)needs replaced on my ford dsl 1600 . Wondering where the best place to buy one?... It has pre -heat as part of the switch... I was thinking about replacing it with a 4 post switch and using a seperate push button for the pre-heat? Thanks in advance. John
(quoted from post at 11:49:28 11/03/14) The ignition switch (5 post.)needs replaced on my ford dsl 1600 . Wondering where the best place to buy one?... It has pre -heat as part of the switch... I was thinking about replacing it with a 4 post switch and using a seperate push button for the pre-heat? Thanks in advance. John
CNH dealer.
Thanks, I forgot C/IH merged/ bought? with new holland... That will make finding parts easier. C/IH dealer is 30 miles away. I be owned the 1600 20 yrs. Its been a dependable tractor. Only replaced the tires and water pump.
