Torque Generator on 861
Hi guys, putting a loader on my 861 diesel.Thinking of using a Char-Lynn generator and the loader pump for power steering. Anyone have pics of the brackets they used after they cut the steering column to mount the generator. Using an old Wagner loader of of my 9N. Has what looks like an original pump. Was wondering about pump flow, since I read that the generator needs less than 1500 psi? Thanks for the help!!
Typical agg pressures can run from 800 the 2500 psi fmdepending the equipment. I wouldn't be surprised if that pump was in the 2250 to 2500 range. What about getting Ps column, then use a priority valve off the loader pump?
