FiddlinFarmer
After running well most of the summer, I went to start my '66 Ford 2000 3-cyl.
1) It cranked well, but never fired.
2) I upped the throttle a little bit and when I cranked it, I saw quite a bit of gas come out of the carburetor. With this, I ruled out the fuel pump.
3) I assumed it must be flooded, so I shut off the gas at the shut-off valve and cranked it with the throttle still up. Didn't get anywhere that way, so I went the other direction and checked the spark.
4) I was getting a good consistent 1/4" jump on the spark.
5) I pulled the air hose off the carb just to make sure it was getting plenty of air, but there was no change.
6) I pulled a spark plug and it was very dry, so there doesn't appear to be any fuel making it into the engine.
Since choking it with the throttle up causes gas to run out the bottom of the carburetor yet the spark plugs are dry, should I assume that the carburetor is fouled up, or is there something else I should look into first? (btw - it is a Holley carb, so I am guessing it is the original and from other things I've seen, I doubt anything on this tractor has had much maintenance over the years)
