rear axle leak ford jubliee
cthanse
have replaced oil seals on both rear axles appx'10 hrs ago. rt rear axle is leaking oil around axle nut. I put blue rtv sealer on all mating parts. could axle or hub be worn, causing leak? thanks for any help
There is a seal that goes over the axle followed by the hub which seals between the axle and the hub.. (8N 4251 D) Did you forget it?
Yes, worn hubs will wear the seals. Not sure on the timing.
Check out John Smith's site for procedure and pictures to see
if you got it all correct and to see how the hubs should fit.
Here's a link
I don't think I forgot any of seals, but will check when I pull it off , thanks for your input, chanse
thanks for the link to john's site I 've looked at it, before I started replacing seals, he is very good about details. thanks again for your reply , cthanse
