(quoted from post at 21:54:49 10/26/14) This subject was brought up a day or two ago.. I am of the belief that timing cannot be the problem.
(quoted from post at 22:09:46 10/26/14) Larry! How can no spark at the plugs effect timing?
(quoted from post at 11:54:32 10/27/14) When an engine keeps running after you shut it off its because
the timing has made it run hot. When your manifold gets too hot
and you shut off the tractor the momentum carries your fuel air
mixture up into the exauste side of things causing ignition. This
will happen when the exauste valve is still a little open. If you
look carefully when it keeps running It is actually running
backwards. This is called dieseling. Fix the timing and adjust
the carb a little bit and it will be fine.
(quoted from post at 20:35:45 10/27/14) Tie a string on the coil wire to kill it, until you find out what is
wrong.
(quoted from post at 19:09:27 10/27/14)(quoted from post at 20:35:45 10/27/14) Tie a string on the coil wire to kill it, until you find out what is
wrong.
What????? jerking the coil wire won't do any more than turning off the switch will.
