Ford 861 dual clutch setup questions
wabrand
New User
I have a Ford 861 with a slipping clutch. I split the tractor today, and am weighing my options. The PTO clutch is fine, so I would like to replace only the transmission clutch disc. I have an NDA-7502 fixture to set up the clutch, but I don't have the NDA-7502-3 spacers. Does anyone know how thick these spacers are? I also would like to know where to find new pressure plate spring seat retainers, as none of the on-line vendors seem to have any. The Ford shop manual says I can't re-use the old ones. Thanks for your help!
If you can waite till morning, I will measure mine and let you know. I have the clutch jig also. If you are in dire need of the clips, I would give Hy-Capacity a call
Hear ya go. The one marked top is 10 and a half thirty-seconds..The other one is 3/8 measure by my mechanical slide rule, and I would have bet there was more difference than that.
I get clutches etc from Hy-Capacity, since I have a dealer within 3 miles. I don't believe you can buy from them directly.
