Won't start
4cyl diesel or 3 cyl?
if a 3 cyl, is the fuel stop pulled, ( check at the pump in case the cable broke ).
if a 4, make sure sure the throttle linkage is moving at the rossa master pump.
is she making smoke when turning over?
if equipped with thermal start aid, is it working?
Do you have a charger or booster cables or jump pak on it? They will crank all day at just under the required RPMs and still not start. Your scenario will help a lot as well. Did you just find it in a barn? Did you just perform maintenance? Has been running well then just suddenly won't start? Don't leave anything out. There is a wealth of information here but very poor mind reading skills.
I Put a new battery and starter check thermostat sending unit check fuel sending unit needs replacing the tractor was running good before I did all these checks there is no smoke when cranking pull stop push in
(quoted from post at 08:43:54 10/26/14) I Put a new battery and starter check thermostat sending unit check fuel sending unit needs replacing the tractor was running good before I did all these checks there is no smoke when cranking pull stop push in
Do you have a charger or booster cables or jump pak on it? They will crank all day at just under the required RPMs and still not start. Do you have a good dribble of fuel coming out of the lines at the injectors?
