My Ford 600 has been running rough so I started with the plugs. Ended up replacing plugs, leads, condensor, and points. After this, tractor has no spark.
If I break the points openI get no spark or a very weak one. Touching the distributor shaft I get a strong spark. I also cleaned the connections coming out of the coil. I don't understand why there would be no spark at the points. Just for kicks, I put the original condensor and points back in and had the same problem.
Any ideas?
Any ideas?
