Ultradog MN
- Location
- Twin Cities
I'm doing a little networking here.
One guy I know has an NOS Ford built 3610 diesel short block. Another guy has a 3000 diesel that the cylinder walls are badly scored and would need the whole shebang - sleeves, pistons, crank grind, etc.
Before I steer the two together I want to make sure the new engine will work.
Primarily, I need to know if the 3610 is a 175 so he wouldn't need a new pump and injectors.
Also, would the 3000 head fit on the 3610 block.
I think they changed head bolt diameter somewhere along in there.
Thanks for any advice that I can pass along to help a guy out.
