tourque amplifier
if i install a tourque amplifier on the steering shaft on my naa to gain power assist steering, where and how would i tap into a high pressure oil source?
(quoted from post at 14:45:29 10/22/14) if i install a tourque amplifier on the steering shaft on my naa to gain power assist steering, where and how would i tap into a high pressure oil source?
here is no hydraulic high pressure on the NAA except when the lift is actually moving & even that pressure depends on the load being lifted.
I've added PS to a NAA two ways, but both used assist cylinders
attached to the draglinks. One used a pump ran off the fan belt
like the power steering on a car. Similar to the x00 series.
That can be a challenge if you're not good at fabrication, but
it may be your only choice if you don't have a loader.
Which brings up the second option. If you have a loader with
a stinger pump run off the front of the engine, you can tap into
the output of that pump with a variable priority diverter valve.
This was taken when I was fitting the control valve.
