Ford 800 Charging Problems
jollymon
I am having charging troubles on a Ford 800. The battery shows 6.4v not running and generator showing 7.4v running. The battery is not charging. I replaced the regulator and polarized (field to bat). It worked perfectly for two days and is now no longer charging. The amp meter did showed a constant charge when it was working, maxed out all the time but now shows nothing. I suspect the regulator again but it is brand new. Bought from yesterdays tractor. I checked all wires coming off the generator and they all show continuity with the chassis. Is this correct or do I have a short causing max charge and burnout? Any help is appreciated. Thanks
(quoted from post at 12:12:36 10/21/14) I am having charging troubles on a Ford 800. The battery shows 6.4v not running and generator showing 7.4v running. The battery is not charging. I replaced the regulator and polarized (field to bat). It worked perfectly for two days and is now no longer charging. The amp meter did showed a constant charge when it was working, maxed out all the time but now shows nothing. I suspect the regulator again but it is brand new. Bought from yesterdays tractor. I checked all wires coming off the generator and they all show continuity with the chassis. Is this correct or do I have a short causing max charge and burnout? Any help is appreciated. Thanks
es, on continuity question. Temporarily jumper regulator terminals BATT to ARM while running & see if charge increases. If not, add a second jumper from ARM to Field & see if charge increases. These jumpers simply simulate the closing of cut out & field contacts within the VR.
Thanks for the info. The BATT to ARM jump increased the charging to 10-15 amps. When I added the ARM to FLD the charging maxed out which is what it was doing before it totally failed.
if it was not charging ( showing on ammeter ).. and jumpering cutout got you charge, and then ading field jumper got you even more. then likely genny is working ok, and vreg is bad.
cutout jumper means cutout is not operating. the fact it showed charge when jumpered means field ckt is likely working.. not that that is any help with cutout open.. etc.
so new reg.. unless you have some big diode laying around. ;)
Before new VR, he should verify that VR case is well grounded to the generator case. Another jumper is easy.
(quoted from post at 10:31:26 10/21/14) never hurts to check
Thanks for all the help. Grounding the VR did not help. The VR is new. Is there anything that could cause the VR to fail or are they made so cheap they have high fail rate.
We see many, many reports of new VR failures (some no doubt real, other may be mis-diagnosis), but I still run perfectly well operating original VRs on equipment that was built in 1950 and 1962. Many suspect cheap/shoddy Chinese junk & I don't doubt it, but also these things are a small production affair today & not the "build all day every day" runs of 50 years ago. With refinements, the cut out is just a relay......voltage on coil makes electromagnet that moves a magnetic 'armature' (metal hinge) and closes a set of contacts.
If the coil current is there and the armature moves, it is usually just dirty/corroded contacts or an invisible insulating film on them that when carefully cleaned will again work just fine. If the wire in coil is damaged, it is junk.
short of prying it open and then poking at it with a probe under test conditions.. not really ;) ( yes )
SOP to keep a lucas vreg going is to clean the contacts yearly..
(quoted from post at 14:12:14 10/21/14) Is there any way to test the VR for a bad coil or bad contacts?
ou can disconnect it from A-F-B, remove VR cover (screws or drill out rivets) and connect a variable DC power supply to ARM & case and slowly increase voltage until around 12.5 to 13 volts it will pull the armature down & close the contacts. No variable DC supply? OK, then a 12v battery in series with one or two flashlight D-cells. Once you verify pull-in, you can use Ohm meter to verify contacts are closing , thus connecting BATT to ARM. If no pull-in, coil likely bad, if pull-in & no BATT to ARM contact, then clean/burnish contacts. You can of course close contacts/armature with your finger.
All a matter of time, capability, interest, etc. If interested in playing, send picture of your VR & I can help with circuit diagram, internals ID, etc. If you can't post picture, my e-mail is open in MODERN VIEW.
