Ultradog MN
- Location
- Twin Cities
Are these a known failure point on these tractors?
Does the big coil spring inside on these break or something?
I've had 3 of these that didn't work.
All the same.
Limp pedal.
Lays on the step plate.
No adjustment going to help.
Never had a problem on a 3000.
I will look in the manual but can you fix it from the right side?
Or do you have to pull the left trumpet and get at it that way?
I ran this 4000 rear end all winter plowing snow and used diff lock a lot.
Now it's limp.
Going to have to learn about them soon enough but the board's thoughts would be welcome.
All the same.
Limp pedal.
Now it's limp.
