Rich in NJ
Last night a friend and I were able to finally solve this on-going and highly frustrating problem. We were able to get both tractors ('57 Powermaster and '63 4000 (4 cylinder, gas)) up and running. The first confirmed problem was that the tune-up kit I bought had the cheapest, crappiest brass spark plug wire connectors that were totally worthless. When these were removed and the old wires replaced, that problem vanished. This was the only problem with the 4000, as it started right up and only required a minimum of adjusting. My Powermaster problem was not only linked to the poor connectors, but with the fact that the cork distributor gasket that goes between the distributor body and the dust shied was about 40% thicker than the original one. This too-thick gasket ended up causing three different rotors to break apart. It's really true that just because parts are brand new, one can't fully trust them due to shoddy specs. In any case, once I placed the original (skinny) gasket back in place and reconnected everything, this engine also started right up and required even less adjusting than the first one. We had previously verified the static timing, so there was no need to remove either distributor. Thank God for all of this, as I can finally get some sleep!!
