My 600 starts fine and idles fine but at higher throttle settings it runs rough. Kinda sounds like the cyllinders are loaded up but I've noticed that I can twist the distributor counterclockwise a few degrees and it runs better. Not like it should, but better.
I'm assuming that's where my problem is but I don't know if there is an adjustment I can make or if I need to replace the distributor, points, etc.
I'm not much of a mechanic but willing to listen and try things.
