Ford 3910 Starter Issues
jvdowling
I was using the tractor, shut it off, went to start it again and got nothing but a "Click". Was told the solenoid might be bad so I took the starter out, had a new solenoid installed, starter was bench tested and worked fine. Put the starter back in and it just clicks. Suggestions please!!!!
You likely have excessive voltage drop in your starter engagement circuit. Check all the wiring from your key switch to your starter, including the neutral saftey switch. Make sure all connections are clean and tight.
Use your jumper cables from another tractor or vehicle and jump to starter. Just be sure its not in gear. This way you will know if it something other than starter. May be a bad connection on battery, safety switch bad or key switch, etc.
