Ford fan in GA
New User
This is about a 1973 Ford 8600 rear half, with a 9600 front half, from the clutch forward. Dual power, no cab.
About a month ago I was spraying, and the main lift would barely pick up the 200 gallon 3pt hitch sprayer. I could rev it up and it would raise, and the pump would cut off and it would stay in place. It eventually got to where it would not pick up at all. We did still have some hydraulic pressure and we were baling hay later and the pto went out.
We called our local mechanic and he was busy, and contacted another competent mechanic who has little experience on 8600's, but lots on 5000's, so we felt he could do the job or replacing the pump. He came over and replaced the pump, bolted everything back up, and no pressure.
We added an extra 5 gallons of oil TEMPORARILY so that if the pickup tube was out, it would still pick up and prime... no luck.
We got another new pump, and repeated, still no luck.Just got through with that today. Got zero pressure on a guage at the rear remotes, although you could feel some oil flowing.
Today, we pulled the filter on the LH side, and ran the camera through the intake tube all the way to the pump, and you can see that the pickup tube is property installed. That is not our problem unless there is a hairline crack that is pulling air. We did install a new o ring at the tube/pump interface.
Tonight, for kicks I pulled apart the old pump and found that the small pump that operates the pto and dual power was fine. On the main pump the steel front gear sleve in the aluminum housing was worn through, the shaft was galled, and the aluminum housing was ovalized. That was the problem. It never really screamed though, even when it would not work. However, there was a lot of metal in the filter that was shedding from the pump.
A local guy with lots of knowledge said that we have a problem somewhere in the main lift. Either a blown o ring in the main lift cylinder, or we think that there might be a piece of metal in one of two valves attached to the main lift cylinder allowing oil to bypass.
Since the rear lift would hold the 2000lb sprayer once it was up, I think the o-ring is probably OK.
What he said is that the main lift gets oil first, and something is going on to where the main lift is calling for oil, but not building pressure. That also keeps any oil from going to the rear remotes.
He also suggested running for a half hour or so and check temperatures of the lift housing, and the oil to see if there is any heat generated to get a clue of where the bypass/leak is occuring.
So we are considering pulling the lift cover off next to check that o-ring, and pull the 2 valve bodies in the main lift assembly to check for metal holding something open.
Whew! That is lots of info, but any comments, suggestions would be appreciated.
Thanks!
D Lee
Ford fan in GA
1973 96/8600
1976 8600
1969 5000
1964 5000 with loader
Thanks!
D Lee
Ford fan in GA
1973 96/8600
1976 8600
1969 5000
