William Fissell
More 841 woes. Never had this many headaches
before.
Background: lift would lift with no weight on it
but would not lift with weight on it. Would leak
down quickly. Pulled lift cover to replace piston
oring.
Cam follower pin was worn 1/2 through so
disassembled to replace. Did so.
On reassembly I was trying to adjust the lift per
Zane instructions. It looks to me as thought the
(new) cam follower pin is interfering with the
draft control plunger spring. See pics.
Do folks think a part is bent?
Thanks in advance.
before.
oring.
Thanks in advance.
